January 18, 2023 at 12:38 am
Theodore St George
SubscriberHello,
I'm trying to get a pseudo-timestep from each cell for a steady-state calculation. I was previously referred to C_DT(cell,thread) which appears to work well with the Density-based solver. However, upon switching to the Pressure-Based solver, even with Coupled and Pseudo Time Method turned to Global Time Step, utilizing C_DT(cell,thread) causes Fluent to hard crash and close. The CURRENT_TIMESTEP command has no such issues, but I don't have any confirmation the timestep is indeed the actual pseudo timestep, not just a value that's held over from the last time I did a transient simulation.
Notably, I can extract a contour plot of the Time Step (Residuals -> Time Step) while using the Density-Based Solver, and I cannot while using the Pressure-Based Solver
Is this the expected behavior and/or are there other commands I should be looking at?
January 18, 2023 at 12:02 pm
Ansys EmployeeCURRENT_TIMESTEP is for transient models. I suspect the C_DT is for the density based solver only, and there may not be an equivalent for pressure based. We're a bit limited in what we can offer for UDF support - other than the documentation. Other community members are not under the same restrictions.
January 18, 2023 at 7:47 pm
Theodore St George
SubscriberUnderstood, thanks Rob.
2630
2110
1335
1110
461
