December 15, 2021 at 2:45 pm
Ales23
SubscriberDear all,
I am trying to parallelize my calculation. However, I am facing a problem with a cell macro:
I have following code:
begin_c_loop_int(c,t)
Message("%e ",C_VOLUME(c,t));
end_c_loop_int(c,t)
For this simple code the simulation crashes. If I want to display C_P(c,t), it works.
Important note: It is 2D simulation.
Thank you for your help
December 21, 2021 at 1:20 pmKarthik R
AdministratorHello Can you please try running a script from the Fluent customization manual to make sure this is not a systems-related issue? Also, what is the objective of your UDF?
Karthik
December 21, 2021 at 2:26 pmAles23
Subscriberthank you. in the end I found the error. I excess a wrong thread
December 22, 2021 at 2:04 pmKarthik R
AdministratorAwesome! Good luck with your projects.
February 25, 2022 at 8:40 amalexandra17
SubscriberHi! I kind of have the same issue here and I do not think it relates with the thread. Every time I introduce the macro C_VOLUME my code crashes. I need to determine the volume of each cell in order to calculate the partial pressure. I have a one phase mixing model with two species air and water vapors. I narrowed down my code to this C_Volume thing because it refuses to work. Every time I insert this I get the sigsegv error. Does anyone has any idea what I am missing here pretty please?
#include "udf.h"
#include "mem.h"
DEFINE_ON_DEMAND(mass)
Domain *d = Get_Domain(1);
Thread *t;
cell_t c;
real vol;
begin_c_loop(c,t)
vol = C_VOLUME(c,t);
Message("%e\n", vol);
end_c_loop(c,t)
February 25, 2022 at 8:43 amAles23
Subscriberyou are not assigning a thread. You have only declared add t=Lookup_Thread(ID,d);
ID is equal to the domain zone
February 25, 2022 at 10:30 amalexandra17
SubscriberHi Ales23! Thank you for your response! I've done that already as I am interested in a certain zone in my domain. The error remains the same. :(
February 25, 2022 at 10:33 amalexandra17
SubscriberI have checked to make sure the ID number corresponds to the zone I want and it does. The code I created works fine as long as I do not introduce the C_VOLUME macro.
February 25, 2022 at 11:18 amAles23
Subscriberbut in your code t=Lookup_Thread() is missing as I can see
February 25, 2022 at 12:45 pmalexandra17
SubscriberI attach my code with the Lookup_thread that I missed. The error remains the same. The ID number is fine. I have checked it already.
#include "udf.h"
#include "mem.h"
Thread *t;
int ID = 5;
t = Lookup_Thread(d, ID);
cell_t c;
real vol;
begin_c_loop(c,t)
end_c_loop(c,t)
February 25, 2022 at 1:09 pmAles23
Subscriberare you using interior ID or cell zone condition?
February 25, 2022 at 3:45 pmalexandra17
SubscriberI am using the ID from a Boundary Condition, I guess that means that is interior ID right?
February 25, 2022 at 3:47 pmAles23
Subscriberyou have to use the one from Cell conditions
February 25, 2022 at 4:43 pmalexandra17
SubscriberOh I see! Thank you very much! It works fine now. However, this is not what I intended. Could you please tell me how to determine the cell volumes for a certain boundary area? I need to calculate the condensation rate on a window in a room.
February 28, 2022 at 4:52 pmRob
Ansys EmployeeHave a look for the adjacent cells, https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v221/en/flu_udf/flu_udf_ConnectivityMacros.html%23flu_udf_macros_f_c0_c1 is a good starting point.
Viewing 14 reply threads- You must be logged in to reply to this topic.
2656
2120
1349
1118
461
