March 2, 2022 at 5:57 pm
shawn.naigle
SubscriberHello, is it possible to export the designmodeler build history into spaceclaim?
A little background: I'm doing a parametric study in Workbench using DM on a student license and want to export the optimal designs for editing in solidworks for 3D printing. As I have a student edition, I cannot export from DM directly, so I am flowing the geometry from a DM component to a SC component in workbench. Then, I'm using a licensed version of SC that's on an HPC to export to STP. This process works, but I lose the build history in the process making it harder to modify.
Thanks
Shawn
March 3, 2022 at 3:10 amKeyur Kanade
Regards Keyur
March 3, 2022 at 3:43 amshawn.naigle
SubscriberThanks, Keyur.
I feared that was the case. I should have used SpaceClaim in the first place. I'll take a look at the YouTube link.
Shawn
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2600
2088
1319
1108
459
