Discovery Import
Discovery Import
CAD Configuration Manager
    • Vojtacerveny
      Hello, I need to connect Inventor geometry to Ansys Discovery geometry on both sides. CAD configuration manager reports error "No valid Inventor installation detected" I have Inventor installed and I work normally in it. Can you help me please?
    • Charudatta Bandgar
      Hello Vojtěch Červený
      Can you confirm if you had done it with admin privileges'?
      Also, will you be able to add the log files mentioned in the screenshot?
      Regards.
      • Vojtacerveny
        🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
        Hello Charudatta Bandgar
        Thank you for your response.
        Yes, I did it with admin privileges.
        I am attaching log files.
        Vojtěch Červený Hello,
        Are you using student license?
        Regards.
      • Vojtacerveny
        Charudatta Bandgar
        Yes, I use a student license for both programs. Is that the problem?
        It is not, but since you are using Student version, I would recommend posting your questions on Ansys Learning Forum which is a dedicated platform for students.
        Here the issue seems to be with the version of inventor. Make sure it is correct versions V6 - 2022, V11 to 2022.
        Regards.
