July 5, 2018 at 3:43 pm
ajones
SubscriberHi, Our client has a temp discovery ultimate enterprise licence and has managed to install the software, licence and the CAD translators package without problems. But when trying to import CATIA files or create new geometry within AIM they get this error.After selecting 'ok' they get
They are able to do both in Spaceclaim as normal. They have now tried it on two machines with the same end result and this is the first ANSYS product they have installed. Any help would be greatly appreciated, Alex
July 6, 2018 at 6:36 am
Naresh Patre
Ansys EmployeeHello Alex I noticed an instance where reinstalling helped to overcome this issue. Also, make sure that they run the setup in administrative mode.-
July 6, 2018 at 12:30 pm
ajones
SubscriberHi Naresh Patre
It has been re-installed, and run in administrative mode. Still gives the same error
July 9, 2018 at 7:10 am
Naresh Patre
Ansys EmployeeAlex I will check with the team and let you know. Meanwhile, you mentioned that this error occurs when trying to import CATIA files or create new geometry. Does it occur even while importing any other file format like stp, parasolid, etc.?
July 9, 2018 at 7:19 am
Naresh Patre
Ansys EmployeeAlex Also can you let me know which version of Catia are they trying to import?
July 9, 2018 at 8:43 am
ajones
SubscriberNaresh Patre Step files show the same error and they have tried using Catia files from versions 21 and 22.
July 9, 2018 at 2:48 pm
Naresh Patre
Ansys EmployeeAlex Can you send following log files located at ~
/Ansys Inc Install.log
Install_licconfig.log
Install.err (if it exists)
July 9, 2018 at 3:48 pm
ajones
SubscriberNaresh Patre I have attached the log files
🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
3780
2587
1831
1244
598
