April 14, 2023 at 2:07 pm
April 17, 2023 at 7:05 am
Aniket
Ansys EmployeeAre you using the student version? The student version supports only the following geometry imports:
If you are using a commercial or research license, please check the units in which each cad part is designed, and make sure that those are consistant.
-Aniket
April 17, 2023 at 7:31 am
Bikbulat Khabibullin
SubscriberYes, I’m using a student version. Does it mean that all of the parts in the assembly must be also step files?
-Bikbulat
April 17, 2023 at 9:12 am
Aniket
Ansys EmployeeYes, those should either be step or iges. They can also be parasolid if you are using DesignModeler.
-Aniket
3363
2471
1310
1018
