September 27, 2017 at 11:19 am
admin
Ansys EmployeeA: In ANSYS CFX, during transient rotor-stator runs, the meshes of rotating frames remain stationary, but the relative position of the flow profiles at the 2 sides of a transient rotor-stator interface is updated each time step. The forces and moments which are calculated with expressions like forcex() or torquex() are therefore calculated in the relative frame of the rotating parts. To get the forces and moments in absolute frame, a coordinate transformation is needed. If for instance the Z axis is the axis of rotation, the forces in X and Y direction ca be expressed as: myForceXabs = forcex()@Impeller * cos(Angular Velocity * Time) + forcey()@Impeller * sin(Angular Velocity * Time) myForceXabs = -1 * forcex()@Impeller * sin(Angular Velocity * Time) + forcey()@Impeller * cos(Angular Velocity * Time) Similarly, moments in absolute frame can be transformed in the same way.
admin
Ansys EmployeeQ: How to calculate forces and moments in absolute system for a transient turbomachinery run ANSYS CFX, during the solver run?
2630
2104
1327
1110
461
