Calculate leakage inductance of matrix transformer
    • satyajitc55
    • Navya C
      Hi @satyajitc55 Have you tried using the PEexpert and PEmag tools that come along with maxwell? These are a good start to build the transformer and perform the calculations shown below. Then the design can be transferred from PEmag to Maxwell for further analysis.
      Please refer
      Look at the PEMag help contents for further information
      Regards Navya
    • satyajitc55
      Thanks Just a couple of doubts
      1. In step2, which libraries we need to load
      2. Can we connect windings in series and parallel
      Thanks
    • Navya C
      1)The component library is by default available in the tool. Step 2 is only required if you have any custom libraries created or you want to import any external data.
      2)You can connect the coils in parallel. Please refer to "Paralleling the layers" in the Help index or for any additional information.
      Regards Navya
    • satyajitc55
      Thanks Much helpful for a begginer in maxwell.
      Between I found several tutorials for anays 2D and 3D for beginners.
      But for PExprt I did not get any document or video to help start setting up the things.
      If you know any source like link, pdf etc for PExprt tutorial please share.
Viewing 4 reply threads
