December 17, 2019 at 7:03 pm
kabit
SubscriberHello everyone,
in order to calculate the mass exchanged across a surface for a steady state simulation, I have created a seperated mesh region. In the post processing, I splitted the region into a surface with a positive normal velocity component and a surface with a negative velocity component. The results of the massFlow function for both surfaces are approximately zero, which should not be the case. Calculating the mass flow by areaint(u*density) gives reasonable results. However, the results for the two surfaces should be equal, but differ significantly.
Does anybody know, why this happens and if there is a workaround for this problem?
December 18, 2019 at 11:40 am
Ansys EmployeeIf you're reporting on an interior surface turn it into a wall (you'll see wall & wall:shadow) and then back to an interior. It's because the interior surface normals aren't set in the mesh.
December 18, 2019 at 2:51 pm
kabit
SubscriberThank you very much for your reply.
Do you know if there is also a way to do this in CFX?
December 20, 2019 at 9:22 am
Ansys EmployeeProbably much the same approach in CFD Post using the velocity components normal to the surface(s) or a flux.
December 20, 2019 at 9:36 am
DrAmine
Ansys EmployeeYou can try using the mesh location for that. For that reason you decompose in pre-processing and then define monitor in CFX-Pre and access the primitive 2D boundary in CFD-Post.
December 26, 2019 at 3:31 pm
kabit
SubscriberThank you both for your help.
The calculation of the mass flow on the interior surfaces seems to work now. However, another problem has now occured. If I calculate the mass flow across an iso-clip surface, I get different results than on the interior surface, even if both surfaces are equal.
Does anybody know, how to fix this?
January 2, 2020 at 11:39 am
Ansys EmployeeHow different? The isosurface will pull data from surrounding cells and interpolate, the interior calculates the value directly with no interpolation. Also remember the issue with normals I mentioned.
January 21, 2020 at 4:57 pm
kabit
SubscriberHi,
sorry for my late respond. I just used the interior surface directly for my calculations to avoid the interpolation errors, which seems to work fine.
Thank you very much for your help.
5242
3299
2469
