January 28, 2022 at 3:58 pm
jo_t
SubscriberHello,
I have 2 identical horn antennas with some geometry between them. One antenna is sending and the other should be receiving. I defined the excitation for the sending antenna and get the correct radiation pattern, but how do I set up the simulation so I can visualize the fields and power received at the receiving horn antenna?
Thank you very much in advance!
January 31, 2022 at 3:52 pmPraneeth
Firstly, you need to save fields in your simulation.
By default, the tool saves fields at the solution frequency.
You can select the co-ordinate system planes and then plot the fields for visualization.
All the very best.
Viewing 1 reply thread- The topic ‘Calculate received fields in a horn antenna.’ is closed to new replies.
Trending discussions- Applying rotor skew
- Effect of region on force calculation
- How to make the available GPU on my Desktop to be used for direct solver simulations in ANSYS HFSS ?
- Parasolid entity check failed for part
- HFSS Parasolid Error
- Induction Heating Simulation
- Co-simulation between HFSS and structural/workbench
- IBIS AMI models
- Radial and Tangential force
- example files
8808
4658
3153
1680
1470
