June 3, 2023 at 4:45 pm
GeorgeAerospace
Subscriber -
June 5, 2023 at 2:05 pm
Chandra Sekaran
Ansys EmployeeThe beam tool ( https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v231/en/wb_sim/ds_Beam_Tool.html?q=beam%20tool ) is what you would usually use for beam results. However this is not supported for Random vibration or harmonic response. You may want to use the Worksheet view as shown below. Also you can use ETABLE items from APDL in a user defined result.
June 25, 2023 at 10:54 am
GeorgeAerospace
SubscriberThank you for your reply.
The Worksheet you mentioned does not display the result values at elements or nodes.
So, I ask my question again, is there any way to display the beam results in random and harmonic analyses?
4430
2949
1422
1322
