STEM
STEM
Calculate the time ⏱️ it will take for cooling down a cup of hot milk   ?  ? ☕️
    • prajput
      How can I calculate the time ⏱️ it will take for me to cool down a cup of hot milk ☕️ by blowing over it ???
    • Akismet
      Hi
      The process of cooling by blowing over something is called Forced convection. The rate of heat transfer can be computed using the Newton's law of cooling - which states that the convection heat transfer rate, q", is directly proportional to the difference between the surface and fluid temperatures. In mathematical terms,
      q" = h(T_s - T_inf)
      where:
      q" - convection heat flux (W/m^2),
      h - proportionality constant referred to as the heat transfer coefficient (W/(m^2.K)),
      T_s - surface temperature, and
      T_inf - bulk fluid temperature.
    • prajput
      Thanks @bsista !!
