Discovery Import
Discovery Import
Calculated value of a partial plane
    • seffa
      When using the "calculated value" feature in Discovery AIM, is it possible to grab information from just part of the plane and not the whole plane itself?
      For example, I have a room where im modeling airflow. Could I create a plane through the middle of the room and find out the average velocity in each half of the plane?
      I understand you can do a contour plot. But the issue is that a contour plot is a continuous field of values which makes it hard to use for design purposes. If I could say, have an average value for each half of the room, then I could use those hard numbers in a calculation.
      I attached a screen shot of a contour plot to show how I would want to break up the data. Each red square I would want to grab an average (AVG.) velocity from for example. Is this possible?
      Thanks!
      Sam
    • Charudatta Bandgar
      Hello seffa ,
      It is not possible to grab information from parts of the plane the way you are expecting.
      I would suggest you to post it in the Discovery AIM ideas section, since it will be a good addition to the AIM result extraction.
