Calculating Factor of Safety Considering Temperature
    • talhaensar
      I conducted thermomechanical analysis by coupling steady state thermal and static structural analyses modules. I would like to calculate the factor of safety according to UTS and Sy. But, I would like to consider the temperature effect to FOS. So, I tought that a way as mentioned below;
      1) Determination of UTS (T) and Sy (T) equations by using fitted curves to UTS-T and Sy-T diagrams
      2) Defining the UTS and Sy values  for each nodes by using these equations,
      3) Dividing the nodal UTS and Sy values to Von-Mises stresses
      I will appreciate it if you can provide macro or any method to define FOS for each nodes.
      Thanks in advance,
      Talha E. Ba?
    • Rohith Patchigolla
      Hi Talha,
      You can do this via UDR.
      Please let me know if you are still interested.
      Best regards,
      Rohith
    • talhaensar
      Hi Rohith,
      I accomplished it by using UDF as using steps shared before.
      Thanks for your concern.
      Bests,
      Talha
