Calculating inlet area using fluent console
    • Meri Gjika
      So I want to calculate the inlet area of my geometry and I was trying using fluent console but I get invalid commands sometimes. Do you know what to write in the script to obtain this number, if you have tips on another way that I can use, that in your idea is better I would appreciate your recommendations.
    • Federico Alzamora Previtali
      You can get this value from Report Definitions > Surace Report > Area.
      You can also create a named expression similarly if you want to use the quantity for something else.
      Just make sure your solution is initialzed to get an output.
