September 12, 2019 at 9:26 am
vinitraj3
SubscriberTo all the experts,
I am trying to understand the concept of interfacial area density for a multiphase problem in which water is evaporating into its vapor. Consider a planar surface. Now I i assume that in a cell (2d) of size 0.0125m the volume fraction is 0.4, the UDF returns me rightly the volume of the cell to 0.00015625. Now I am expecting that the interface area should be returned as 0.0125, since the interface should be planar.
The fluent UDF manual shows gives Interfacial area density as magnitude of gradient of alpha, i.e NV_MAG(C_VOF_G(c, ppt)). So if I multiply this with volume I should be expecting Interfacial area. or
Interface Area = NV_MAG(C_VOF_G(c, ppt)) * C_VOLUME(c, ppt)
Now here is interesting thing
When I use the Green Gauss Cell Based Method i get area densities as approximately 59 which when multiplied with 0.00015625 gives me interface area as 0.00932.
However, when I use Green Gauss Node Based Method, i get area densities around 40 which multiplied with volume gives me 0.00625 (half of the expected interface area). So should I be multiplying it with 2.
I am attaching the UDF file as well as the test case which I have been using.
Help needed in understanding why both methods give different area and what is the physical significance of interface area density
September 12, 2019 at 9:34 am
vinitraj3
Water volume fraction was patched in the bottom two rows and the black horizontal line shows the water volume fraction=0.5 line. I.e the interface cells are one row above the bottom.
The UDF is also pasted here
// The DEFINE_ADJUST macro is used to calculate the interfacial area density
DEFINE_ADJUST(area_density, domain)
#if !RP_HOST // either serial or node
Thread *t, **pt;
cell_t c;
// Allocate storage to store the gradients
Domain *pDomain = DOMAIN_SUB_DOMAIN(domain, 0);
Alloc_Storage_Vars(pDomain, SV_VOF_RG, SV_VOF_G, SV_NULL);
Scalar_Reconstruction(pDomain, SV_VOF, -1, SV_VOF_RG, NULL);
Scalar_Derivatives(pDomain, SV_VOF, -1, SV_VOF_G, SV_VOF_RG, Vof_Deriv_Accumulate);
// Loop over all the cells in the domain
mp_thread_loop_c(t, domain, pt)
if (FLUID_THREAD_P(t)) // Check for threads which are fluid
Thread *ppt = pt[0];
begin_c_loop(c, t) // Loop over all the cells in the thread
if (C_VOF(c, ppt) != 0.0 && C_VOF(c, ppt) != 1.0) // Check for threads which have interface
C_UDMI(c, t, 0) = NV_MAG(C_VOF_G(c, ppt)); // Store the magnitude of gradient of VOF
Message("n Cell Index=%i : Volume fraction=%f: Area Density= %fn", c, C_VOF(c, ppt), C_UDMI(c, t, 0));
//NV_V(A,=,C_VOF_G(c, ppt));
//Message("n Cell Index=%i : Gradient in x =%f", c, A[0]);
//Message("n Cell Index=%i : Gradient in y =%f", c, A[1]);
end_c_loop(c, t)
Free_Storage_Vars(pDomain, SV_VOF_RG, SV_VOF_G, SV_NULL); // Free the storage
#endif // if !RP_HOST
//This method of calculation has been picked up from CFD online dot com discussion forum
DEFINE_ADJUST(area, domain)
Thread *t, **pt;
cell_t c;
face_t f;
C_UDMI(c, t, 1) = 2.0 * C_VOF(c,ppt)* NV_MAG(C_VOF_G(c, ppt)); // Interface area is calculated using the formula Area= 2.alpha.magnitude(grad(alpha))
C_UDMI(c, t, 2) = 2.0 * NV_MAG(C_VOF_G(c, ppt)) * C_VOLUME(c, ppt); // Interface area is calculated using the formula Area = 2* volume * alpha.magnitude(grad(alpha)
Message("n Cell Index=%i : Interface Area1=%f: Interface Area2= %f: Volume=%fn", c, C_UDMI(c, t, 1), C_UDMI(c, t, 2), C_VOLUME(c, ppt));
end_c_loop(c, t)
September 12, 2019 at 11:06 am
DrAmine
Ansys Employeeinterfacial area density is defined to be the ratio of the projected surface area of the bubbles or particles in a cell. Another definition states the volume integral of the area density must be equal to the real surface area. So if one integrate interfacial area density along the normal would lead to 1.
1/If using mixture model or Eulerian Model for phase change there is no need to calculate gradient based Inter-facial area as it is already available option
2/That the value is different for different Green-Gauss approaches that is expected as the two approaches are completely different (node and cell based)
3/You case is bit ill-posed as it is very diffused
4/You will need to sum all UDM'is to get the area
5/If you think that this is defect please get in touch with local support related to the region
September 12, 2019 at 11:26 am
vinitraj3
SubscriberThanks Amine,
The case I have posed is on coarse mesh as I was still testing out my UDF. Once I am clear with things I will go for better mesh resolution.
1. My case is a VOF model where I am trying to write a UDF for mass transfer across the interface of a droplet sitting on a heated surface. For this I need to know how to calculate the interface area in each cell.
2. The interface area is a physical quantity, so should not the different Green Gauss approaches return same interface area.
Your comments on that are most welcome
September 12, 2019 at 11:30 am
DrAmine
Ansys EmployeeGreen Gauss Cell Based and Node Based are completely different stencils to calculate gradients.
September 12, 2019 at 3:45 pm
vinitraj3
I understand that they are different methodologies to calculate gradient. Then in that case which one should be chosen for calculation of area
Regards
Rajeev
September 12, 2019 at 4:29 pm
DrAmine
Ansys EmployeeI would rather worry about the phase change rate as global quantity. Node Based GG approach is more accurate.
2656
2120
1347
1118
461
