August 9, 2018 at 6:31 pm
cehangir
SubscriberHi,
I am using ANSYS Fluent for combustion problem with swirl in 2D.
At the moment, I know the air going in the system is 15 m/s and the diameter of the duct is 0.3 m with 45 degree fins to generate swirls.
Can someone help me finding the swirl angular velocity (rad/s) that I should input in Fluent. If not, can someone tell me how swirl angular velocity is calculated in rad/s, and what information is generally need.
Thanks -
August 10, 2018 at 12:23 pm
Karthik R
AdministratorHello,
Could you please elaborate a little more about your problem? Can you not specify normal velocity and the 45 degree fins will deflect the flow internally when Fluent solves your model? What I don't understand is, I guess, your geometry? Could you please help us understand your problem better?
Thank you.
Best Regards,
Karthik
August 10, 2018 at 11:56 pm
klu
Ansys EmployeeHi,
How about switching to magnitude and direction settings? I would think to put 15 m/s as the magnitude. Assume no radial component thus axial and swirl components are equal since the fins turn 45 degrees.
August 13, 2018 at 5:37 am
DrAmine
Ansys EmployeeIf you do not know anything about inflow then just stick to what klu said and assume normal inflow direction.
August 13, 2018 at 6:35 pm
cehangir
SubscriberI can use normal flow. Unfortunately, my geometry is 2D. Therefore I dont have physical 45 degree fins in the inlet.
That is why I want to include the expected swirl in the inlet.
August 13, 2018 at 6:39 pm
cehangir
SubscriberHi,
Can you elaborate how I can do that by switching to direction and magnitude setting.
Considering I have velocity as 15m/s, what will be the direction components for the axial and swirl component for 45 degree?
I have an additional information that the swirl No. is 0.79. Can I use it in some way to give direction ?
August 13, 2018 at 7:44 pm
DrAmine
Ansys EmployeeSwirl number is the ratio of flow rate of angular momentum to flow rate of axial momentum.
Velocity in cylindrical coordinate is V= r*e_r+(r*tehta)*e_theta+axial*e_axial with e_r, e_theta and e_axial the main cylindrical direction.
Moreover radial velocity=u cos (theta) + v sin(theta), tangential velocity = -u sin(theta) + v cos(theta) und axial velocity is the velocity into the rotational axis.
January 15, 2019 at 11:20 am
SaiKiran
SubscriberHi,
Can you please elaborate u and v components in the radial and tangential velocity. i am also working on the similar problem
thanks & regards,
saikiran
2656
2120
1345
1118
461
