calculation activities and post cfd plots
    • designteam2
      I attached an image below to reference what i am asking.
      In calculation activities you are allowed to choose variables that you want to export. When added those variables, in post CFD when choosing what variables I wanted to plot I didn't see all the variables I chose earlier. How do you ensure that all the variables that you choose to export is available in post CFD? So far I have just been exporting as a CDAT file in calculation activities and then post cfd opens to the most recent cdat file saved.
    • raul.raghav
      Can you mention which variables do not appear in CFD-Post on export from Fluent?
    • designteam2
      Variables that do not appear : Absolute pressure of the mixture, DPM velocity magnitude, DPM volume fraction, DPM y velocity.
      Particle tracking export variables that do not appear: particle velocity magnitude, particle reynolds number, particle current time.
      Additional Question: What is the difference between DPM and phase 2 (which is the discrete phase).
    • DrAmine
      Are you doing a sort of dense discrete phase simulation (DDPM)?
      Can you double-check if you have really selected the variables you mentioned for the cdat export? Which version are you using?
    • designteam2
      Yes it is a DDPM. We double checked and all the variables we wanted to export from calculation activities are cdat. It is a student version 19.2.
    • Keyur Kanade
      did you select variables to export before running?
Viewing 5 reply threads
