Calculation of inductance matrix without return conductor and with return
    • hujun peng
      I am using Eddy current solver to calculate the frequency-dependent impedance for electrical motors.
      I want to calculate the inductance of each conductor and their coupling.
      At first I use one pole simulation as follows.
      Then, I excite two neighboring conductors as follows:
      Then, the inductance matrix will be set as
      I run the simulation at 20 kHz,
      I get the results as follows:
      However,  they values are too small.
      Then, I run the simulation for a pole pair, and the model is
      For the excitation this time, I uses winding and coils.
      the first coil
      the second coil
      Then, the inductance matrix is set:
      afte Simulation, the results are
      The results are much larger than the result in the first case.
      However, I suppose a factor of 2 between them because a turn consists of two conductors.
      Therefore, my question is, why there is such a large difference. Which is one is correct for my application, i believe that the second results are more true.
      Thank you.
    • Navya C
      Hi hujun peng,
      In the second case, the resistance seems very high(4.5 Ohm) for just one turn. I feel, may be, the first case makes sense and there is something wrong with the second case.
      Navya
