August 20, 2019 at 12:29 pm
marduin
SubscriberI know that in CFD Post the torque of a surface can be found using a command like torque_x()@location. But what is the actual internal equation or process that CFD Post and Ansys use to calculate the result from this command?
August 30, 2019 at 6:51 pm
fkelecy
Ansys EmployeeI know that in CFD Post the torque of a surface can be found using a command like torque_x()@location. But what is the actual internal equation or process that CFD Post and Ansys use to calculate the result from this command?
The moment vector on a surface is computed as the surface integral of the cross product of the position vector r=xi + yj + zk with the local force vector Fx i + Fy j + Fz k at point (x,y,z). Note that the position vector is relative to the origin of the coordinate frame (0,0,0). The net moment computed in this way is a vector quantity Mx i + My j + Mz k. We can then take the dot product of the moment vector with any axis unit vector to get the torque about the axis. In CFD Post, you can choose the x y or z axis, thus is will give you Mx, My, or Mz.
hope this helps,
Frank
May 27, 2020 at 10:51 am
2534
2066
1285
1104
459
