March 16, 2023 at 8:36 pm
Tarek BENALI
SubscriberBonsoir à tous
Je désire savoir comment clculer la surface d'une roue sous forme cylindrique non uniforme 3D, sous Ansys Electronics Desktop -
March 21, 2023 at 12:27 pm
Navya C
Ansys EmployeeHi @Tarek,
You can select all the faces by holding the control key and then Right mouse click > measure>face.
You can switch to the face-selecting mode by clicking the F key on the keyboard.
Navya
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
3744
2573
1803
1236
594
