August 29, 2022 at 9:29 am
mohammedlaminemekhalfia
SubscriberDear
I hope this post will find all users well,
as a followup for my problem considering the plot for campbell diagram for a Bladed disk (60 blades).
I was wondering if there is a possibility to make ansys draw the campbell diagram for more tham 180 modes?
I tried that but I had the following error:
"Campbell Diagram data is not complete. Please refer to ANSYS output file for possible causes." The following information is what I deduced after outputting the file from the solution branch (Write input file) and looking through the error file which says "there's no data related to the campbell diagram."
I tried previous suggested solution about creating a new database but that did not work.
August 29, 2022 at 12:44 pm
Aniket
Ansys EmployeeCan you also include the error messages in the solver output file?
-Aniket
August 29, 2022 at 12:56 pm
SubscriberThis message I got when I reduced the number of modes from 180 to 121 but for the first case it was mentionned a lake of files ( corrupted database ) for the memory I am sure that I have sufficent alloacated memory (RAM) and storage capacity of hard disk.
PRINT CAMPBELL DIAGRAM
Sorting : ON
X axis unit : rd/s
Driving component : CM_ROTVELCITY53
Printout all frequencies
*** FATAL *** CP = 14177.062 TIME= 16:52:51
This model requires more scratch space than available. The program has
currently allocated 39439 MB and was not able to allocate enough
additional memory in order to proceed. Please increase the virtual
memory on your system and/or increase the work space memory and rerun
the program. Problem terminated.
ALL CURRENT ANSYS DATA WRITTEN TO FILE NAME= ansabort.db
FOR POSSIBLE RESUME FROM THIS POINT
The above error is non-recoverable by ANSYS
ANSYS run terminated by the indicated error
Current data base saved if possible. -
August 30, 2022 at 5:18 am
SubscriberThis is the message when I try with 180 modes
fAnsMemAllocL with negative length= -1060200976
This is probably due to an integer overflow in
the calculation of the block size.
The data type is= 3 and the block name=
Sorting : ON
X axis unit : rd/s
August 30, 2022 at 4:31 pm
Aniket
Ansys EmployeeThis basically means you do not have enough RAM to solve the problem, you may want to try it with a machine with higher RAM.
-Aniket
August 31, 2022 at 6:16 am
2110
1335
1112
461
