March 18, 2021 at 10:18 am
jasonsum25
SubscriberIn case a gas pipe contains some water, I want to use an air compressor to pump air into the pipe and blow the water away. nCan this software simulate and find out the air pressure needed for blowing the water out?n -
March 18, 2021 at 12:30 pm
Karthik R
AdministratorHello, nYes, you should be able to do this using Ansys Fluent. You will need to solve a Multiphase Model for this one (in particular - the Volume of Fluid). There are several examples on YouTube on this topic and watching these might get you started with your model. nKarthikn
Trending discussions
Top Contributors
2524
2066
1285
1096
459
Top Rated Tags
