September 19, 2023 at 4:49 am
Eric Yu
SubscriberI am new to LS-DYNA and have a couple of questions about LS-DYNA and its relation to ANSYS. I want to do a fluid-structure interaction simulation with immersed boundary method. I am confused with the LS-DYNA available in ANSYS workbench. Based on an old user guide (2017) I found, it mentioned that workbench LS-DYNA cannot handle two-way FSI problem. Is this feature included in the new version of Ansys?
If not, is it true that the FSI problem can only be done via LS-RUN? Can I use Ansys product launcher to call LS-DYNA solver to run FSI problem directly?
I am also curious about whether you can use ANSYS-LS-DYNA to do preprocessing. I noticed that you can export k files from workbench setup for solids, can you do that for fluid as well? Can you export user-defined material from Ansys to k file?
Thanks!
September 20, 2023 at 1:51 pm
Ram Gopisetti
Ansys EmployeeHi
With newer versions of LSDYNA WB, you can run the ALE, CEL methods.
That method is not recommended anymore, use the LS-RUN instead.
Yes, you can use it for pre-processing, you can also do for fluids modelled with ALE, SPH and ISPH.
No, you cannot export user-defined material from Ansys to k file.
Cheers, Ram
September 25, 2023 at 12:00 am
Eric Yu
SubscriberHi Ram,
Thank you so much for the information. As a followup, is there any tutorials on how to do FSI problems through workbench LS-DYNA and is ANSYS 22R2 new enough?
Thanks!
Eric
- Explicit dynamics ERRORS
- explicit dynamics
- turning simulation
- Monte Carlo Simulation
- How to solve Energy error too large
7742
4502
2963
1449
1322
