March 10, 2022 at 7:33 pm
harsha2209
SubscriberI have a udf for finding the dynamic contact angle. I interpret this code usually and is working perfectly fine in serial mode. I want to parllelize this udf to reduce my computation time. Can someone help me to parllelize this udf? I went through Ansys udf manual but still I am not able to do it. Please help
#include "udf.h"
#include "unsteady.h"
// Initializing values
double time=0,adjust_starttime,last_time=-1;
double dynamic_contact_angle, equilibrium_CA = 124.0, Ca;
int first_time=1,first_adjust=0;
double sum=0.0,R;
FILE *datafile;
float d=3,u=0.5;
// DEFINE_ADJUST is used to manipulate the values
DEFINE_ADJUST(Contact_Angle_Adjust, domain)
Thread *thread = Lookup_Thread(domain, 6); // zone_id = 6
Thread **pt = THREAD_SUB_THREADS(thread);
cell_t cell;
face_t f;
double x_hoff;
int n;
sum=0.0;
if(first_time==0) //after droplet touches the surface
if(CURRENT_TIME!=last_time){
printf("inside firsttime =0 ");
time=CURRENT_TIME;
last_time=CURRENT_TIME;
if(first_adjust==0){
adjust_starttime=PREVIOUS_TIME;
first_adjust=1;
Ca = (0.001/(2*0.0702))*sqrt(3*u*0.001*d)/sqrt(time-adjust_starttime); // v = sqrt(D*0.3/t)/2
printf("Ca = %f ",Ca);
x_hoff= Ca + 0.00402;
if(Ca>=0){
dynamic_contact_angle= acos( 1-2*tanh(5.16*pow((x_hoff/(1+1.31*pow(x_hoff,.99))),0.706) ) ) *180.0/M_PI ;
else{
dynamic_contact_angle= 2*equilibrium_CA*(180.0/M_PI)-acos( 1-2*tanh(5.16*pow((x_hoff/(1+1.31*pow(x_hoff,.99))),0.706) ) ) *180.0/M_PI ;
printf("DCA = %e",dynamic_contact_angle);
datafile = fopen("datafile.txt", "a+");
fprintf(datafile,"%f %e %f %e ",Ca,time,dynamic_contact_angle,adjust_starttime);
fclose(datafile);
if(first_time==1) // to check if the droplet touched the surface
begin_c_loop_all (cell,pt[1])
sum+=C_VOF(cell,pt[1]);
end_c_loop_all (cell,pt[1])
//R=sqrt(sum*1.0e-08/M_PI);
if(sum>0){
first_time=0;
// DEFINE_PROFILE is used to set the contact angle value
DEFINE_PROFILE(Contact_Angle_Set,t,i)
face_t f;
begin_f_loop(f,t)
F_PROFILE(f,t,i) = dynamic_contact_angle;
end_f_loop(f,t)
March 11, 2022 at 4:45 pmViewing 1 reply thread- You must be logged in to reply to this topic.
2524
2066
1279
1096
457
