November 20, 2020 at 2:29 pm
JOELGEORGE
SubscriberI am new to this Ansys software. I am recently doing a project of simulating a bird event. For this project I need to mesh the bird with hexahedral element (then converted to smooth particle), and the airfoil with shell elements of 0.5mm with seven integration points, with average element size of 10mm. nI just need to the procedure for doing this meshing. nThanks in advance. n n -
November 23, 2020 at 6:01 pm
December 11, 2020 at 6:45 am
July 5, 2021 at 4:30 pm
MaAdel
Subscriber.JOELGEORGE
I'm same in your situation
Could you tell me how you fixed, please
July 7, 2021 at 8:15 am
JOELGEORGE
Subscriber.Hi Maadel,
Firstly sorry for the delay in my response. Please do have a look at this youtube video by CADFEM https://www.youtube.com/watch?v=nkOMQAXxwDE, its given in Russian language, but you will get an idea to start with. Hope you will figure out with this.
Best Regards,
Joel George.
- Explicit dynamics ERRORS
- turning simulation
- explicit dynamics
- Monte Carlo Simulation
- Error inside ANSYS LS Dyna: “An error occurred inside the SOLVER module: general error.”
8806
4658
3151
1680
1470
