September 21, 2022 at 6:30 am
Weidong
SubscriberI would like to couple DEM and ALE in LS DYNA. For example, a ball modeled by DEM, and it drops into water (ALE). Could you please give me some suggestion? Thanks so much.
September 22, 2022 at 11:46 pm
Reno Genest
Ansys EmployeeHello Weidong,
There is an example of a sphere dropped in water here:
It is not DEM, but if you have only one sphere, you could mesh the sphere with regular elements and have the sphere rigid:
You will find papers here:
https://apps.dtic.mil/sti/pdfs/AD1011313.pdf
https://www.dynalook.com/conferences/15th-international-ls-dyna-conference/fsi-ale/comparative-analysis-of-occupant-responses-between-ls-dyna-r-arbitrary-lagrange-in-euler-and-ale-and-structured2013ale-s-ale-methods/view
https://www.dynalook.com/conferences/14th-international-ls-dyna-conference/blast/comparison-of-strategies-for-landmine-modeling-in-ls-dyna-with-sandy-soil-material-model-development/view
You can search for more papers on dynalook.com website.
Also, DEM particles can be coupled with the iCFD (incompressible CFD) solver in LS-DYNA:
https://www.dynaexamples.com/icfd/basics-examples/demcoupling
Reno.
September 23, 2022 at 12:12 am
Weidong
SubscriberHi Reno,
Thanks so much for your help. Your response is helpful for me.
Best regards,
Weidong
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
2642
2110
1335
1112
461
