March 2, 2022 at 2:38 am
ROSELJR
SubscriberCan the data converted by the sensor through the analog-to-digital converter be directly sent to the computer wirelessly and solved by the program in the computer?
If yes, is it first to add a microcontroller to the device and then send it out, or to send it directly, which one is better?
March 14, 2022 at 11:33 amChinmay T
Ansys EmployeeHi It looks like the question does not belong to simulation or physics related but on analog to digital converters.
So as Ansys employees, we may not be able to provide you correct advice.
We will leave it to the forum community who can guide you better.
Thanks,
Chinmay
- Maxwell, HFSS or Q3D?
- Error
2656
2120
1347
1118
461
