Can I define springs with coincident nodes defining each end? Can I use one spring element to define
October 4, 2017 at 12:20 pm
pgl
Ansys EmployeeThe spring cannot be defined at coincident nodes because the node locations determine the spring orientation. The longitudinal spring element stiffness acts only along its length. The length change can be considered in the 3D space. You need to define multiple springs for different directions.
- How to deal with the error message about “You have specified result time (or frequency) = xxxx for a
- What is cause of error: display time for result item greater than the step end time?
- Any suggestions on speeding up convergence behavior with surface-to-surface radiation?
- If SCDM issues the message “Cannot open the document. Reason: Failed to load body geometry.” and the
- In a harmonic analysis, is the damping produced by MP,DMPR; TB,SDAMP; and DMPSTR constant vs frequen
- Can I define springs with coincident nodes defining each end? Can I use one spring element to define
- Check
- While projecting surfaces/curves onto cylindrical surfaces, the final shape sometimes deteriorates.
- Can you limit the expansion of modes to only those modes with a high participation factors by using
- Why the section plane icon is grayed out in Mechanical windows ? How to make the section plane windo
5340
3341
2471
