Tagged: designmodeler, face-split, fluid, fluid-solid-interaction, fsi
April 2, 2022 at 7:13 pm
El_Manguangua
SubscriberI am studying a fluid-solid interaction between the air (fluid) and an aircraft wing (solid). Since Spaceclaim is not really working out for me (long story), I am using Design Modeler, and "Shared topology" is not really great quality in design modeler, I am using face split to properly mesh contacts and not have an excessive number of elements while meshing, and this makes perfect sense for me for the solid parts of the system, but, can I do the same with the fluid? I'm attaching a picture of the skin of the wing, which outer faces are the fluid-solid interface for the solid.
April 4, 2022 at 4:42 amKeyur Kanade
Ansys EmployeeYou can use tools - face split option in DM.
Please go through help manual for more details
Regards Keyur
April 4, 2022 at 4:48 pmEl_Manguangua
SubscriberHi kkanade, thank you for your answer.
I wasn't asking if Design Modeler would let use face split in a fluid, I meant that, if I indeed use face split in a fluid body, would it somehow affect the physics of the problem?.
Since air is flowing, does ANSYS consider the fluid volume as an actual volume that the fluid is occupying, or does it consider ita physical space in which the fluid is flowing? If it is the second one, then there should not be any problem with using face split on a Fluid domain.
Did I make my question clear?
April 5, 2022 at 6:20 amKeyur Kanade
Ansys EmployeeFluent will consider the body you created for fluid in DM or SpaceClaim and meshed in meshing.
Trending discussions- ANSYS Workbench Measuring within Design
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2524
2066
1279
1096
457
