September 26, 2017 at 5:42 am
admin
Ansys EmployeeHow can I filter my selection in ANSYS SpaceClaim Direct Modeler?
September 29, 2017 at 11:35 pm
pgl
Ansys EmployeeYes. Click the white cursor arrow in the bottom right corner of the design window on the status bar to display the selection filter, which is a drop down menu that shows all selectable entity types. Turn off Smart selection, then toggle which entity types you would like to remain in your selection. Changing tools turns the filter back to Smart. SpaceClaim retains these settings the next time you enable the selection filter.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2726
2146
1357
1150
462
