Can I imitate the solar Load model in 2D?
    • Yannice
      Hi ANSYS forum,
      I would like to imitate a 'solar load' (radiation varying in strength AND direction during the day) in FLUENT in 2D. I know that this option is only available in 3D.
      Do you have any ideas/tricks how I could obtain approximately the same effect but then in 2D, maybe by introducing UDFs? And what radiation model is then suggested?
      Kind regards,
      Yannice
      You could cheat and make the 2d model 3d by making it one cell thick. Problem is the solar track will almost certainly go off plane. A transient expression may be better, link the radiation vector (or heat load) to time.
    • Yannice
      Hi Rob Thank you, smart solutions! How do I exactly link the radiation vector to time?
      And is there a way to obtain the information about solar angle & intensity from the FLUENT model? (So that I can put it into an own expression for 2D)
      You'd need an expression or UDF. Have a look at the wall radiation bc in Fluent.
      Re the intensity, there will be an equation somewhere, have a look in the documentation as we may reference where we got the data from.
Viewing 3 reply threads
