Tagged: 2-way-fsi, fluid, fluid-structure-interaction, slice
April 9, 2022 at 1:45 pm
El_Manguangua
SubscriberI'm currently studying a two-way Fluid-Structure Interaction (FSI) between air and an aircraft wing, and while I managed to do some structured meshing with the wing by slicing its skin into multiple parts and hence reducing the number of elements, I haven't managed to do so with the fluid volume. I'm thinking of doing the same for the fluid volume, but I don't know if that could somehow change the physics of the problem.
If I indeed divide the fluid volume to aim for a more structured meshing how should I define the contact between the fluid volumes? Bonded? Or should I define the fluid domain as a multibody part? I'm not a fan of multibody parts, since they have brought me some trouble in the past. I'm attaching a picture of my fluid domain:
April 11, 2022 at 12:39 pmSwathi V. V.
Ansys EmployeeHello I guess you are using Ansys meshing! You can make use of the Body of influence or sphere of influence sizing option available,if you don't want to split the geometry.
Mesh> Insert > Sizing> Type : Body of Influence.
Trending discussions- ANSYS Workbench Measuring within Design
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2656
2120
1345
1118
461
