March 7, 2022 at 11:07 am
rupakkumar
SubscriberMarch 7, 2022 at 2:25 pmRam Gopisetti
Ansys Employeeyou can simulate it , you may want to use the revolute joint with the initial velocity to the body to solve the problem. But for the SPH, i don't think you can add a joint you may want to position it at an angle and use initial velocity to that plate.
Cheers Ram
March 8, 2022 at 1:22 ampeteroznewman
SubscriberI don't see any hinge in the description.
I see a Flier Plate travelling vertically downward with a velocity of 350 m/s with a 7 degree angle to the Base Plate. The left corner hits first and the impact causes aluminum debris particles to spray to the right with a velocity of Vc.
You can model this in ANSYS using a SPH model.
Trending discussions- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
2524
2066
1279
1096
457
