Can I use adjust on UDS with overset meshes
    • puh69
      I have an adjust hooked onto my overset mesh simulation to define a UDS0. However, this appears to fail when for this but works on a regular mesh. Is there any reason for this and can I work around it?.Thanks,nnPiercen
      It doesn't say you can't in 2020R2, but it depends what you're doing to/with the scalar. If you test on a simple model without overset does the same setup work there?n
