September 14, 2023 at 1:05 pm
庆瑞 张
SubscriberWhen an object is more complex, and on a certain surface to see that the object has multiple 3D structures overlapping, in this case it is very difficult to select a face, because there are some faces inside the object, it is very difficult to select with the mouse, so I hope to add a combination shortcut Ctrl + mouse wheel, hold down Ctrl, slide the mouse wheel is used to switch all the faces of the mouse arrow position.
当一个物体比较复杂时,而且在某个面上看这个物体有多个3D结构重叠,在这种情况下选择一个面就非常困难,因为有一些面在物体的内部,非常难以用鼠标选中,所以希望可以添加一个组合快捷键Ctrl+鼠标滚轮,按住Ctrl的时候,滑动鼠标滚轮用于实现切换这个鼠标箭头位置的所有的面。
September 14, 2023 at 2:10 pm
Atharv Joshi
Forum ModeratorHi,
Let me check this and get back to you.
Thanks and Regards
Atharv
September 15, 2023 at 1:42 pm
Atharv Joshi
Forum ModeratorHi,
Currently its not possible to add combination of shortcut options which will help you with such complex selection. “Ctrl + Rolling the mouse wheel” helps you select internal faces. You can refer to this help document on Power Selecting Objects (ansys.com) which helps selection based on geometric similarities.
Thanks and Regards
Atharv
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
7646
4468
2957
1427
1322
