February 28, 2017 at 9:04 am
Nikita
Ansys EmployeeJuly 21, 2017 at 6:14 pmpgl
Ansys EmployeeYes you can!
In the Zoom group in the Navigation screen in SpaceClaim Options, select the Always radio button. This changes the way query select is controlled. To enable query select, hold the Ctrl key as you roll the scroll wheel.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2120
1347
1118
461
