TAGGED: ansys, ansys-mechanical, ansys-workbench, transient-analysis
May 12, 2022 at 11:52 am
Beryl
SubscriberHi Friend,
I'm trying to use this model to simulate the stress condition under different loading speed, and want to get the strain rate during the process.
I want to know if I can get the strain rate with Transient structure or I should change for Explicit dynamics section?
And if yes, how to get the strain rate result?
Looking forward for your kindly help!
May 17, 2022 at 2:08 pmJohn Doyle
Ansys EmployeeYou can. However, if inertia effects (i.e. acceleration and damping of mass) are negligible, you might want to consider running this as a rate dependent static analysis, where end time has real meaning and rate of loading is important, but inertia effects are not considered. If in doubt, run it as a full transient and as a rate dependent static and compare the two results.
- A solver pivot warning or error has been detected
8762
4658
3151
1678
1456
