February 4, 2022 at 8:06 am
ejhan
SubscriberHi, I installed sherlock and wanted to use "local library" but can not find.
February 8, 2022 at 9:41 pmANSYS_MMadore
Ansys EmployeeIt should be located in user>appdata>Roaming>Sherlock. https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v221/en/sherlock_ug/sherlock_ug_40a_creating-a-part-library.html?q=local%20library
February 9, 2022 at 1:39 amejhan
SubscriberI found the folder but local library doesn't appear in sherlock.
I can see only sherlock part library, and can not update my parts at local library.
I did confirmation of all parts.
Trending discussions- Error with workbench SceneGraphChart
- License Error
- Workbench error
- Workbench not opening
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
3862
2639
1859
1254
600
