Preprocessing
Preprocessing
can not generate the mesh
    • justnarendra
      hello ansys world   i want to do the aerodynamic simulation of car model in ansys fluent but i am not able to creat the mesh.   please find the STEP file with this post and let me know what steps should follow.   many thanks in advance
    • Keyur Kanade
      Can you please insert images. As ANSYS employee, we can not download attachments.
      Also please have a look at following video which can help you to mesh.
      Keyur
    • justnarendra
      hi . soon i will upload the pics but at the moment i am not able to see the video link
    • justnarendra
      https://grabcad.com/library/the-lamborghini-terzo-millennio-concept-car-1 this is the link of the step file from grab cad
    • Karthik R
      Administrator
      Here are some video related to meshing a car using Workbench meshing.
      Please see if you can use them to learn how to mesh. Also, as per Keyur's suggestions, please share some more details about your geometry and we can provide more specific instructions.
      Thank you.
      Best Regards,
      Karthik
    • Keyur Kanade
      Thanks Karthik, I forgot to share link for video.
    • justnarendra
      hi here are some screenshots please let me know how should i proceed
    • justnarendra
      please find the geometry above
    • justnarendra
      Hard to tell but it looks like you've got a volume and the car is a collection of surface bodies. This will mesh, but possibly not as you intend. Also, if you read the error message I think (hard to read) that you've got some poor surface cells. Have a look at the surfaces and do some clean up.
    • justnarendra
    • justnarendra
      do i need to close the car body and what about the contacts ?
      Depends on what you're trying to achieve: Cars tend to be closed (unless they're convertibles) and contacts means you didn't create multibody parts.
      Looking through the errors, line two is the most useful: have you got very small faces on the car or sharp angles on the surfaces?
    • justnarendra
      this geometry has 18 parts which are small and few are large as well and 40 contact regions
    • justnarendra
      https://grabcad.com/library/audi-r8-mesh-2d-1 is the link of the geometry
    • Keyur Kanade
      If you want aerodynamic study as shown in video, please create a solid out of surfaces. Then create outer domain and use subtraction to get fluid domain.
      Please try to start with simple shape as shown in the video. Get familiar with the procedure. Then use your geometry.
      Keyur
    • justnarendra
      the mesher did not generate any nodes what does it mean ? and tried but i am not able to generate solid out of surfaces any tutorial which might help me ?
      Have a look at the surfaces and see if they create a sealed volume: assuming they don't what do you need to do to close it?  I doubt there is a specific tutorial, but have a look at the DesignModeler examples.
    • justnarendra
      thanks
    • Keyur Kanade
      For closing that car body, you may need to create some more faces so that it can have a closed region. After than please use body operations - stitch command in DM to create solid body.
      Keyur
    • Keyur Kanade
      Sorry, its 'sew' and not stitch.
      Keyur
    • justnarendra
      thanks keyur
    • justnarendra
      Operation would result in non-manifold bodies i am getting this error.   i closed all the bodies but still i am not able to creat boolean
    • Keyur Kanade
      Did you get a solid in model tree?
      Go to tools -- analysis tools -- fault detection. Check if geometry has any faults.
      Keyur
    • justnarendra
    • justnarendra
      please take a look ...
    • Keyur Kanade
      Use Create - Thin Surface and faces except the faces which are giving problem of self intersection. Use thickeness of zero.
      Then recreate those faces to patch the hole. Then again use sew command to create solid.
      Keyur
    • justnarendra
      hi Keyur as u said i am using very simple geometry at this time but still i am not able to creat the domain please take a look again and there is no fault in the geometry
    • Keyur Kanade
      From images, it is still a surface body. Please use sew operation only for surfaces. Please suppress line bodies.
      Keyur
    • justnarendra
    • justnarendra
      still i am not able to creat thin surface
    • Keyur Kanade
      Looks like you already of surface body.
      Keyur
    • justnarendra
      hi now i created a solid body and i am also able to create boolean but can not transport the geometry to mesh
    • justnarendra
      it is a plug in error
      Try to link to a new mesh component. It's possible the workflow has corrupted with all of the changes.
    • Keyur Kanade
      I see that it is already a surface body.
      What you need to do is following -
      Use Sew operation to create a solid body of this surface body.
      Then create outer domain and use boolean operation for subtract.
Viewing 35 reply threads
