Tagged: gds, gdsii, Import-and-export-gds, lumerical, parametrization
March 10, 2022 at 5:50 pm
Pascalito
SubscriberHello,
I was wondering if after importing a GDS file into lumerical, can we parametrize that design. Assume you import a ring resonator from a GDS file, can you for instance parametrize the ring's radius?
March 18, 2022 at 6:51 pmKyle
Objects created from GDS files are fixed once they are imported. However, we recently introduced a feature that allows users to import PCell geometries from Cadence Virtuoso. There is more information on this page: https://support.lumerical.com/hc/en-us/articles/4412939657107
- Error on Lumerical device
2688
2138
1351
1136
462
