Can the parameters system generate a cloud map?
    • h395523899
      I simulated a flow field and generated the corresponding exit flow parameters by changing the boundary conditions through the parameters system.
      But can I use the parameters system to generate a cloud map for each condition? I need to save the cloud map for each condition.
      The exit parameters exist in a table, but I'm not sure what you mean by a "cloud map" as to me that's a representation of a geometric surface comprised of points only.
    • h395523899
      Whether this function can display speed or pressure contours under each condition.
      Do I still need to open results after each calculation of a condition, look at speed or pressure contours and take screenshots?
      I think you mean the data files and not parameters. The former contains all of the flow data and the latter is a single number.
      The simple way is to open each design point in turn and save an image. If you use CFD Post, a report can be created which can then automatically dump images into folders associated with each design point.
Viewing 3 reply threads
