Can UDF access the variables generated during simulation directly?
    • uceczw4
      I want to use the UDF to customize the granluar viscosity. In the new expression of granlar viscosity, some variables calculated by the Simonin turbulence interaction model (14.5.18.3.1.1.2 in Fluent theory guide) will be used, for example the k_pq. Is there a name of k_pq that I can use directly in the UDF, or I have to include the expression of it in the UDF and calculate it again?
    • Keyur Kanade
      As far as I know you will need to include expression in UDF.
      Please go through help manual for more details
      Keyur
      • uceczw4
        Thnan you so much. It seems like I've to code these expressions in the UDF
      It's almost certainly calculated on the fly by the model, so there won't be a memory allocation for it.
      • uceczw4
        I understand. Thank you so much.
