April 18, 2018 at 9:36 am
maurya
Subscriberhello sir
can we create virtual topology in spaceclaim geometry ?
i want to draw external features on body after virtual topology is it possible in spaceclaim geometry?
thank you
April 18, 2018 at 11:49 am
SubscriberIn SpaceClaim, you are creating topology.
In Mechanical, if you don't like the the topology you have, you can improve it by using virtual topology.
Similar tools to Mechanical Virtual Topology are available in SpaceClaim like split edge, split face, etc.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
5290
3311
2471
