can we deactivate some elements in a full domain.
    • Jayakrishna
      Hai,
      In static structural, is it possible to isolate some elements so that simulation results will not be effected by those elements?
    • Aniket
      Do you want to remove the results on these elements in post-processing or want to remove them before solving them?
      For the first option, you can customize the legend to show a grey color for the excess result.
      Or you can create a worksheet based named selection, to filter out the elements that you do not want to show results on.
      For the second option you need to use EKILL command from APDL.
      -Aniket
