November 16, 2018 at 8:14 am
MarkHo
SubscriberHi
I am currently UCSD student and have some questions about RedHawk.
Can we dump the spice netlist, which include p/g network and current sinks from RedHawk with generate simulationdeck command? If so, could you give me an example. If not, which command should I use for exporting the spice netlist from RedHawk?
Thanks a lot~
Best Regards,
Mark
- Maxwell, HFSS or Q3D?
- Error
2656
2120
1347
1118
461
