February 9, 2021 at 4:34 pm
AissamRiad
SubscriberHi Community,nI was wondering if we could use Ansys maxwell 3D geometry directly in Ansys fluent without create a new one from scratch, and if it's the case how could i do itnnthanksn -
February 9, 2021 at 5:27 pm
Karthik R
AdministratorHello, nTo solve a Fluid problem in Fluent, your geometry needs to be the 'fluid' region. So, if you have this Fluids region in your Maxwell geometry already, then you can use this 'Fluids' geometry. nAlso, you cannot use the geometry directly in Fluent. You will need to create the mesh file based on the geometry. Fluent can then read this mesh file.nThank you.nKarthikn
5364
3363
2471
1310
1018
