March 11, 2021 at 8:25 pm
Ansyslearner112
SubscriberHi nI am pretty new to DesignModeler and am trying to setup an 2d model of a nozzle (cross sectional view) firing gas through a hollow frustum (basically a cone with a hole) which is some distance away. I am trying to represent the frustum as two straight lines diverging away from each other but when a draw the line and try and create a surface using edges I am unable to do so (I think this maybe because you need a closed loop to form a surface from edges)nIs there any way I can represent a line as a surface which fluid must flow around?nThanks n -
March 15, 2021 at 6:31 am
Keyur Kanade
Ansys EmployeeCan you post some images. nYou will need closed loop. You can create an edge at the hole and then create surface. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
Trending discussions
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
Top Contributors
2564
2080
1299
1106
459
Top Rated Tags
