September 1, 2022 at 2:32 pm
crumberg
SubscriberI am attempting to import shear stress data from Fluent to Mechanical in Workbench. Workbench only gives the options to import loads as "body temperature" or "pressure" the way the model is currently set up. The research conditions I am comparing my model to, however, consider shear stress rather than pressure. Is there an output control in Fluent that would send shear stress data to Mechanical instead of pressure data?
September 2, 2022 at 5:30 am
Nikhil Narale
Ansys EmployeeHello,
The pressure force variable that you are importing in Mechanical is the composite total force, which includes both the pressure and the viscous forces from Fluent.
In your case, you may have to play with the results during post-processing.
Thank you,
Nikhil
September 2, 2022 at 3:23 pm
crumberg
SubscriberThanks Nikhil. Just to make sure I am understanding correctly, this means that the "pressure" force at each node is not necessarily normal to the surface but is the sum vector of the normal and shear forces at that node?
September 5, 2022 at 7:41 am
Nikhil Narale
Ansys EmployeeYes, you got it right.
September 13, 2022 at 9:28 pm
crumberg
SubscriberEdit: reply removed because the problem described therein resulted from selecting the incorrect import region
2656
2120
1347
1118
461
