May 6, 2022 at 1:42 pm
FeRo220
SubscriberHello,
I am using the 2021 R1 version and would like to save it as an older version, maybe 2019 or 2020.
Does SpaceClaim allow for this?
I looked through the options, but couldn't find anything related to this issue, but not sure if I missed anything.
I know in some other programs, you're allowed to do this.
Thanks,
Jon
May 6, 2022 at 6:08 pmpeteroznewman
SubscriberThere is no Save As to an older .scdoc version.
If you have a paid license for the 2021 R1 version, you can Save As a neutral file such as Parasolid or STEP. When saving as Parasolid, you get to choose the version of Parasolid you want to save as. That means you need to know the version of Parasolid that ANSYS 2019 was using and use that or an earlier version.
If you have the free Student license for 2021 R1, you can't Save As a neutral file at all so you can't go backwards.
May 6, 2022 at 7:19 pmFeRo220
SubscriberThank you for your response.
I tried saving my 2021 model to a step file then open it up in an earlier version, but kept on getting error messages.
I'm able to open step files created in other CAD programs as well as those created in 2021 SpaceClaim, but for some reason I just can't go backwards in SpaceClaim.
May 16, 2022 at 11:49 pmANSYS_STUDENT1
I have a paid academic license for Ansys 2021 R2, however unlike previous versions of space claim I canÔÇÖt save as an IGES or Step neutral file. I can only save as a .Scdoc. Is there any way I can export my geometry from space claim to a neutral format?
May 17, 2022 at 10:34 ampeteroznewman
SubscriberDid this computer every have the free ANSYS Student installed on it before?
If so, was that old software removed? The free version does not let you save in any format other than .scdoc.
Where did the installer for ANSYS 2021 R2 come from?
May 18, 2022 at 1:08 amANSYS_STUDENT1
SubscriberHi
I reinstalled the program and was able to find the save as drop down menu. Thanks
Viewing 5 reply threads- The topic ‘Can you save a SpaceClaim .scdoc to an older version?’ is closed to new replies.
Trending discussions- pcb
- No longer possible to import f3d with 2023?
- line bodies and surface body shared topology
- How to chang unit in Ansys Discovery 2023?
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- SpaceClaim Script: Selection by FilterByBoundingBox
- Assignment of revolute joint
- Max/min over time results in AIM
- Axisymmetric model – Rubber seal
- To change language in Ansys Discovery
8808
4658
3151
1680
1470
